Cause 1
Shock Absorber
One or more of the shock absorbers might be broken or worn out. The shock absorbers dampen the vibration of the washer tub. If one or more of the shock absorbers are worn out, the washer will vibrate or shake. Sometimes, when a washer is moved to another location, the shock absorbers can separate. Check the shock absorbers to ensure that they are positioned correctly, and inspect them for damage and wear. If one or more of the shock absorbers are broken or worn out, we recommend replacing all of the shock absorbers as a preventative measure.
Parts
Shock Absorber for your Samsung Washing Machine
RepairClinic Item #2020946 $24.39
Washing machine shock absorber. This shock absorber prevents the washer from vibrating by absorbing the movements of the washer tub.
Cause 2
Leveling Leg
Check to see if the washer is level, and adjust the leveling legs if necessary. Always lock the legs in place after adjustment to keep them from getting loose.
Parts
Leveling Leg for your Samsung Washing Machine
RepairClinic Item #1796743
Leveling leg assembly
$23.27
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
