Released by Samsung in March 2016. Model SM-G930.
424вопросов Показать все
Screen won't work after dropping in water
I dropped my Galaxy S7 in a carbanated beverage and now my screen only works after my phone dies and I charge it. If I take the charger off it still works until the battery gets low and then it quits again and I have to wait
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
With water damage, you have to decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road.
Not every water-damaged phone is recoverable and depending on the kind of liquid (salty, dirty, filthy), sometimes the success rate is quite low. That said, IMHO, it's always worth a try otherwise we are just piling up the e-waste.
The proper way treat a wet phone is to do the following:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
A professional repair shop that does water damage repair may be able to recover your data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no data/no fee policy so you don't have to spend money to find out if the data is recoverable or not.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Kass v будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 764
