Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
5103вопросов Показать все
Phone turns on then screen goes blank
The iPhone 6 (64 gb) turns on and then the apple logo comes up on screen, but then the screen goes blank. The blacklight stays on though and the screen has got a couple of hairline cracks. Has anybody got an idea on what I should do to resolve this issue? I have no clue about the history of the phone I picked it up for £20.00 off gumtree.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 0
Комментарии:
When you plug it up to iTunes, can you see the phone? What status is It in?
из
It does show up on iTunes, I have no clue how to check what status it is in. :)
из
My first thought was that this is a battery problem. You mentioned that the Apple Logo showed up but then the screen went blank. This, is one of the symptoms of a old, dead battery. So try replacing the battery. If that doesn't work, then my last go is the dock connector. It probably has eroded away a bit. Try replacing the dock connector. If that doesn't help, then its the logic board... But really if the two other ones didn't work than i cant be sure of anything now.
из
@kon_dev Thanks a lot. It turned out to be a software issue but I am thankful for your advice!
из
Добавить комментарий
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
Shop Kits
Enough RAM
For All The Tabs
Shop Kits
1 ответ
Выбранное решение
First lets try using 3UTools if you have a windows computer once you have that downloaded and install open 3UTools and plug the iPhone to the computer.
It’ll then tell you which mode the iPhone is in. It is most likely in DFU / Recovery mode. As this is a phone picked off on gumtree there’s nothing to lose so try doing a restore you can also do this via iTunes as well and see how it goes.
Был ли этот ответ полезен?
Оценка 3
Комментарии:
Thanks a lot. I am so grateful. I tried this method first because I have quite a tight budget so didn't want to buy and fit a new battery and/or dock connector.
из
Добавьте свой ответ
Rafay Siddiqui будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 53
