Will a SATA 2 HD work correctly?
I would like to know if I can change the original HD in my macbook pro first generation? I found models like western digital scorpio black or seagate ones. For example this: http://www.amazon.com/Western-Digital-WD...
thanks for the answer.
Ben
Это хороший вопрос?
Оценка 3
1 Комментарий
I just installed a WD sata I disk, it works fine! It is the one sold on the website
из
Добавить комментарий
2 Ответов
Выбранное решение
Yes, SATA 2 hard drives are backward compatible and will work on your machine, although they will only perform at the slower speed. iFixit also sells hard drives for your machine.
Был ли этот ответ полезен?
Оценка 3
The short answer is yes. Everything works, I've even installed Vista SP2. However, I ran into a problem with my machine/HD combo that I'm still working out.
See this Question/Answer Link
Also here is my Discussion about it.
I'm currently awaiting a 5400 RPM drive from Seagate to see if that will work in my situation. I'm not sure what I'll do if it doesn't.
YMMV.
Оценка 1
Добавьте свой ответ
ben будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 4,493
