Отремонтируйте ваше устройство
Обучение ремонту
Магазин
4хдюймовый iPhone выпущенный в марте 2016 года на той же самой платформе что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
889вопросов Показать все
Front camera won't work when using replacement screens
Hey! I’ve got two high quality replacement screens off eBay. They contain all the parts such as the home button the earpiece and front camera, etc. With both screens, when I plug all the ribbon cables in, the front camera doesn’t work. It just takes black photos and the photos don’t even get saved to my camera roll. I did have great difficulty plugging the front camera ribbon cable into its socket on the phone with both screens, but I think that they are now plugged in properly as they clicked into place. Does anybody have a solution? Thanks. The front camera on my old screen works fine when I put it back on the phone and the cameras on both replacement screens is aligned fine. The rear camera works fine too. Thank you!
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Okay, I have finished replacing the screen. The problem was that the ribbon cables were pretty low quality. It took a lot of attempts and praying but I just had to plug in the ribbon cable and then press all the edges individually into place with a plastic spudger. It took a lot of tries because whenever I plugged in one edge another came out but after a few minutes of fiddling around I plugged the camera in successfully. It now works perfectly and is indeed OEM quality. The home button had a poor ribbon cable too so I just used my original home button from my original screen because I wanted to keep touch ID.
Thank you all for your contributions, especially @refectio because you were pretty much right.
Был ли этот ответ полезен?
Оценка 0
Комментарии:
If I was "pretty much right", why didn't you select my answer as the solution?
из
Because you said that they were low quality and I needed to replace it with my old one when really I didn't need to I just needed to have patience and keep trying.
из
Наиболее полезный ответ
“High Quality” and “eBay” are not words that usually go together when it comes to iPhone replacement screens :>). There are some high quality screens available on eBay but often times they are bottom of the barrel from a quality standpoint and yet the seller will tell you it’s OEM or original. Unless you paid top dollar for a screen, it is not high quality.
The problem with screens that have the front camera pre-installed, even high quality ones, is that the FCAM flex is of lower quality. It’s always better to replace the flex with your Apple-original flex that came with the original screen. In this case, you can see that the original FCAM works fine so just transfer it over to the replacement screen. Check out this guide.
Оценка 3
Комментарии:
Hey, is there another option? The front camera on my old screen has a huge crack on it from when the phone was dropped. The ribbon cables are connected fine the camera just doesn't function no matter what screen I use. I have got some from amazon too and I have never had many problems until now. Cheers!
из
U just said the original works fine when u try it so transplant the original from the old screen to the new screen... like minho said Ebay screens are literally the cheapest rubbish screens that no one else wants to buy and a screen with all the parts is usually one where the parts dont work at all... transplant the old camera flex and make sure u switch off the phone each time ur plugging and unplugging things...
из
@c9679 the camera works but the edge is darked out because of a crack where the phone was dropped. Do you know what the fault could be? I don’t think it’s a hardware issue because even an OEM camera from an original Apple device won’t work. Thanks
из
Is the dark edge on the camera that's working in the broken screen have u took it out of the screen and tried it??? Clean the lens with a cotton bud and try it without the screen
I'm not sure if theres a difference but maybe the cameras u have are for an 5s and ur fixing an SE
из
I have tried the camera from the broken screen on the new screen and I have cleaned it but there is pretty obvious damage to it because it was dropped very badly. I’ll have a go just fiddling around with it and trying the solutions from you guys and I’ll let you know how it goes!
из
Показать 6 больше комментариев
Добавьте свой ответ
Rafay Siddiqui будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 86
