Drilling stripped screws out
Hi there, I have some T3 screws, at least it used to be until it's pretty much stripped.
I have try tipping the screwdriver with cyanoacrylate, hammering the screw head with a flathead screwdriver to create a slot, rubber band.
I'm seriously considering to drill the screw since some are recessed, so I can't dremel it.
Here are the specification of the screws.
1.38mm stem diameter
2.68mm head diameter
counter clockwise to unscrew
I'm considering to use a 1/16" drill bit.
Some questions I wanted to know the answers before proceeding.
Will some of the screw left behind so I can't install a new screw into the hole?
Does the rotation of the drill bit matter?
Это хороший вопрос?
1 Комментарий
Drilling the horribly damaged screws: You really have to start with the smallest drill bit you can find. Drill a small hole, run the drill slowly and be very careful to not break the bit or go too deep. Start really small because it might help save the threads. I had this happen with a repair I was doing, the screw was jammed and I could not budge it. I started out small, and straight (very important) and going slow and steady. I got the drill through the first time and tried to get a thin tapered piece of square stock in and it didn't grab, so I went with the next tiny size larger bit, and finally got enough of the screw removed so that the taper was able to back the rest out. The threads were nearly perfect, and a new screw fit and held. Just use patience, and do not go too big with the bit. Ruining the threads won't be repairable and you would have to glue the guts back in. Most big box hardware stores have really small drill bit kits, or Amazon. etc.
из RobCow
