Technics SA-5550 anti-shock timing circuit
1976 Technics SA-5550 stereo receiver was working perfectly. But then I used air blaster on it to clear out dust, and the the “anti-shock timing circuit” stopped functioning. The literature on this describes the anti-shock timing circuit as “helps eliminate annoying thumps in the speaker after turn-on by delaying turn-on of the speaker terminals”. What is the remedy? Is it possible dust got lodged in the circuit?
Это хороший вопрос?
3 Комментариев
Sounds odd. Are you sure you didn't bump or drop something inside?
из mike
I'm quite sure I didn't bump or drop something inside. I only used the dust blaster.
I should add that when powered on, the lighting and the radio signal strength meter are still working.
из mchlgrblsk
DO u still have the receiver I am looking for one thx crickern @ gmail com
из Fernando Flores
