Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Дата выхода 19 сентября 2014 года. Это большая версия iPhone 6 с 5.5-дюймовый экраном.
1479вопросов Показать все
sim not supported for verizon on verizon network
I have installed an iPhone 6 Plus Logic Board / Verizon / 64 GB to replace my iphone 6 plus logic board verizon. When I installed my Verizon Sim Card, I get the message Sim not supported:
the sim card that you currently have installed in this iphone is from a carrier that is not supported under the activiation policy that is currently assigned by the activation server.
If the Iphone 6 plus logic board is not verizon how to I identify what carrier it is?
i have checked the IMEI number, it is compatible with verizon.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Комментарии:
If it was me I would get a GSX report for your phone they are only a couple of dollars. If not I would find the country of sale through 3Utools and then input the imei number into all those carrier databases. The only phone I have encountered that message on turned out to be carrier locked which is shared on most networks. Good luck.
из
Добавить комментарий
2 Ответов
Выбранное решение
Apparently, the new logic board you installed wasn’t a Verizon board. You need to contact the seller as they apparently shipped you the wrong board.
Был ли этот ответ полезен?
по рейтингу 1
The logic board is locked to AT&T. So i must unlocked the phone using the At&T site, or go to an illegal site and pay 50-100 dollar to AT&T unlocked
по рейтингу 0
Добавьте свой ответ
DAVID NGUYEN HANG, demona будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 49
За всё время: 849
