Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
64вопросов Показать все
Broken a/v out port?
I recently purchased a WU-1A adapter so I can wirelessly upload pictures from my camera to my smartphone. When I tried to plug in the adapter to my camera, it appears the a/v out port on my camera is broken. How do I fix this?
Update (06/05/2019)
This is not the best picture, but this is what it looks like @oldturkey03
Это хороший вопрос?
Оценка 0
3 Комментариев
@hags82 how did you diagnose this? Has it ever worked?
из
@oldturkey03 Yes, it used to work. The adapter will not plug in fully, so I looked into the port, and it doesn't look right. Wish I could show a pic.
из
Sir my out side camera broken not working
из
Добавить комментарий
1 ответ
Выбранное решение
@hags82 It may be difficult to find a replacement. I’d start with disassembly and see if you can even get to it. Hope you got another camera to take lots of picture while you do so. that way we can follow you along. we’ll try to find a replacement part etc. This guide should help you to get there Nikon D3200 Motherboard Replacement
Update (06/05/2019)
@hags82
that looks like the part that moves the contact out of the way to close the connection. If you have a small screwdriver see if you can push it to the outside. BTW the pins on your micro USB look kind of “chewed up” Not sure if that is your picture or if it is really the connector.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Sarah будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 498
