Metallic connectors inside key fob not attached to silicone button pad
My metallic connectors inside key fob not attached to silicone button pad & have become detached - so the whole fob is no longer working. What is the best adhesive to try and re-attach the metal connectors to inhibit them from wondering around causing a mess?
Это хороший вопрос?
4 Комментариев
Can yo post some pics so we can see what you are facing here Adding images to an existing question
из Dan
You appear to be missing some of the pads! Correction: I count five here two is still in the key and three on the table. You need seven!
из Dan
The key fob only shows 5 buttons on the front. There are 3 on the table and 2 of them still in the key fob. They look pretty dirty and need cleaned to make a good connection with the board.
из Joshua Freeman
All these comments are good, but I had the same problem with my key fob. When the discs become dislodged that particular button will not work. Mr personally,I used Super glue, just a touch...
из Ray Sanders
