My pc doesn’t recognize my ram
I tried using different locations but none work with ether stick.
Это хороший вопрос?
Это хороший вопрос?
Have you checked that the RAM Module is compatible with the PC that you are using? If you have, then inspect the physical RAM Module to make sure that there is no damage to any of the pins. Also check the bays that you are inserting the RAM into as these might also be damaged. If you have done all of these and there are no issues, check the BIOS to see if the RAM is actually being picked up as installed.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 45
