add water stays on
No matter what i do the add water light stays on
Это хороший вопрос?
Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
There is a magnetic float sensor in your reservoir that is stuck in the down position. Fill up the reservoir to the max level and tap the side of the reservoir until the float is free (this works better if you remove the reservoir first). You can also use a magnet against the side of the reservoir by the float to help jiggle it free. If this doesn’t work, there is most likely an obstruction blocking the float sensor. Clean the reservoir thoroughly.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 156
