Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281вопросов Показать все
Internet connection doesn't work
Hello, 1 week ago when I turned on my laptop I had a problem with internet connection. Impossible to load Chrome or any software needed internet. Finally 15min later I achieved I don't why..
Now the problem is come back and I can't use internet with my MacBook. The WiFi'Mac seems good, no error.. I tried to connect the laptop with the internet box and my hot-spot mobile, same issue. The problem is not about the internet box because 2 friends use it with their Laptop.
I followed some instructions on internet to fix my problem and finally reinstall ios. But even with ios reinstall (with USB) the wifi is connected but safari doesn't load like other softwares that need internet.
If someone can help me :)
Это хороший вопрос?
Оценка 0
1 Комментарий
Safe mode and system restore doesn't work. How I can install a anti-virus without internet conexion. I've downloaded a software with a other laptop but they need to download some update during the installation..
Format the ssd doesn't delete all virus? I tried but same issue.
EDIT :
I've tried the Macdonald's wifi and it's work. I don't understand, why my phone can be connected to my internet box and not my MacBook.
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
First thing I would do is run a virus scan with a good (Paid For) anti-virus.
To check start up in Safe Mode by holding down the Shift Key on start up and see if your problem persists.
Был ли этот ответ полезен?
Оценка 3
Firstly roll bk to your last system restore point and see if it works.this gives you a window to narrow down the problem.
If no joy then
Try updating your software /drivers as sometimes old ones become obsolete causing loading problems. Also do a full malware scan.
Оценка 1
I followed this tuto and fix my problem.
http://osxdaily.com/2016/09/22/fix-wi-fi...
Оценка 0
I thought fix my problem but the day after same issue, no internet conexion.. If someone have an idea.
Thanks
Оценка 0
Добавьте свой ответ
pierrebouaye44 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 122
