Airport cable socket removed from motherboard-No wifi or bluetooth
The ribbon cable Socket on the logic board which connects to the airport ribbon cable is not working and looks broken. I am wondering if anyone knows how I might fix this problem without buying a $500 new logic board. Is it possible to unsolder and re-solder the connection for the ribbon cable to the logic board? or is this a deeper issue that will require a logic board replacement?
Это хороший вопрос?
1 Комментарий
Looks like it got mangled! Someone clearly didn't have the right tools or skills to remove the cable properly.
из Dan
