Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Proximity sensor won't work.
I have replaced the front assembly on my iphone 4 and it went smoothly. Everything seems to be working properly except the proximity sensor. It won't even kind of work, it will absolutely not go dark EVER.
I restored it because I read that may help if it's a software issue. Is it because of the shiny purple tinted screen? It is just a design flaw or is there something I can do to fix it?
Это хороший вопрос?
Оценка -1
Добавить комментарий
4 Ответов
Выбранное решение
I had exact same problem w mine. I did the electrical tape with two squares cut out over the sensor and now it works great. You just cut a small piece of tape and cut out two squares over the two sensors on the phone not the LCD. The sensors are still open to receive light it just goes around them. I'm not sued how it works but it did. Hope this helps.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
For me, the electrical tape over the small squares and cutting a small holes on it worked flawlessly!
из
Chances are there was a piece of film that you did not transfer at the time
take it apart again,get the old panel and compare to see if it has one
If not,clean these parts or you may have a more serious issue
Оценка 0
2 Комментариев:
Do you mean the blue film on the back of the front piece. I took that off... What could the more serious issues possibly be? any idea?
из
Did you swap that over? if not,you will need to find that or find a EXACT MATCH like it at a craft store to fit it in place,and the material needs to match in color,density,and type of material
из
Here is the best iPhone 4 proximity fix sticker I have found. Here is where you can get it. Read the reviews. It works guys! I have used it on 50 phones so far with just 2 that it didn't fix, and those 2 were already janky in the first place so......
http://www.ebay.com/itm/250888416604
Оценка 0
some clear tape and a black marker saves you some time...
Оценка 0
Добавьте свой ответ
blacplastiq будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 3,195
