Repair manuals for different types of musical instruments, including guitars and keyboards.
285 Questions Показать все
Yamaha Digital Piano P45 - C and F# don't play
Hello, the C and F# keys on my Yamaha P45 digital piano stopped working this morning. C and F# pairs on the 5th, 6th and 7th octaves and the last C8 key. I didn’t find any dust on the contacts. I tried reversing the ribbon cable which connects the higher octaves to the middle board, same result. Then I tried reversing the 27 pin flex ribbon cable that connects the keyboard to the PCD, same result. All the diodes on the keyboard showed the same output.
Has anybody else faced this issue? Any help will be appreciated.
The alternate functions of these keys didn’t work either. So these keystrokes are not getting registered. Either no signal transmitted or no signal registered.
Thanks!
KJ
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Android Fix Kits
A new screen or battery is one kit away.
Купить сейчас
Android Fix Kits
Купить сейчас
1 ответ
Наиболее полезный ответ
Hi,
The answer in this link may be of some help.
Yamaha p-45 keyboard with several keys not making sound
It is for a P45B so hopefully it is close enough to your model to be relevant.
The notes are “generated” by a +3.3V supply being fed through to the selected keys and back to the microprocessor on the appropriate input for the note.
The circuit diagrams in the service manual should be of great help in finding the problem.
Был ли этот ответ полезен?
по рейтингу 1
Добавьте свой ответ
Kaushik Jay будет вечно благодарен.
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
За всё время: 130
