The page roller makes a very loud noise
when I am printing, the page roller makes a very loud annoying sound. What can that be, and how do i fix it?
Это хороший вопрос?
Это хороший вопрос?
Check HERE (HP's video on noisy printer) ... is that the sound you are referring to?
SOURCE: HP (I work for an HP authorized service provider)
Был ли этот ответ полезен?
video link does not work
You may want to try again tomorrow. if it's still down... something will happen. Just don't know what right now...
The link is still down.
link still does not work
I tracked down the video he was originally trying to send using some info contained in the link itself.
You can find it here:
In this case follow these instructions step by step:
First check if the toner drum is properly inserted and not lose from any side.
Then try cleaning your feeder rollers by using a C2C solution or use alcohol swabs. Because sometime a jammed roller often causes annoying sounds and cleaning fixes it.
I have a konica Minolta magicolor 1600w.I found the terrible squeak was $&*!^$^ from 3 peices of felt In the fuser unit that where pressing against the pressure roller.,over time They get a thick layer of ink on them that turns into shiny plastic jackets.so the shiny plastic jackets pressing on shiny roller as it turned was the problem.I don't know if all printers have theses felt pads but it might be a good thing to check on yours ?.I just took mine apart and sanded them down to remove the jackets.And no more squeak..I hope this may help some of you .cav1066.
I just had this problem, then realized, upon inspection of the newly installed cartridge, that I I had left one of the pieces that was meant for removal on the toner cart. Check to ensure that you have removed all packaging from the cartridge before installing!
За последние 24 час(ов): 3
За последние 7 дней: 19
За последние 30 дней: 102
За всё время: 71,946
