Dyson v6 fluffy brush motor replacement
Hi! My dyson motorhead just broke. I disassembled the brush and found the motor was broken. Tried to fix it but i saw sparks and smoke coming from the inside so I have to replace it. I have disassembled the motor too and kept all the original cylinders, screws and plastic cover. So i only need to find a compatible electric motor and re-assembly everything. My question is, how do i know which motor is compatible? It shouldn’t be difficult to find one in aliexpress but i don’t know what to look for. Somebody could help me please? Thanks!
Update (07/08/2019)
I’ve uploaded 2 pictures. 1st picture is my broken motor with the plastic part that I haven’t deattached yet. The other picture corresponds to another dyson v6 fluffy brush motor fullydisassembled
Upper line numbers: 1030986
Lower line numbers: 9S0231 C3
Это хороший вопрос?
9 Комментариев
Hi @mg_alie,
Your pictures are not there.
Here's how to do this in case you're not sure. Adding images to an existing question
из jayeff
Hi @mg_alie,
Did you find some way to replace the broken motor (only) ?
Do you have any link for the motor part or @jayeff for the mini motorized tool (it’s out of stock on your earlier link) ?
из jsn
Hi @jsncrdnl ,
Try putting the part number/model number into the search box on this webpage and check if there are any results
из jayeff
How did you seperate the plastic from the motor? Any hint?
из Thomas Koller
I had to destroy the old motor but it doesn't not bring much. Inside on the axes is an gear with 24? that is stuck on the axes. That you can't take it off (i couldn't) neither to replace it. Inside the plastic is also 2 torx screws you have to take out under the metal washer where the same gear is...i stopped there. For me is no way to fix it ..any suggestions?
из Andra-Emilia
Показать 4 больше комментариев
