Второе поколение было представлено как модель 2003 года на Чикагском автосалоне 2002 года. Автомобиль был построен на новой платформе Impreza и получил ряд улучшений по сравнению с предыдущей моделью.
Why is the engine knocking after overheating
I ran the car out of oil almost completely and it overheated it's never overheated before it's been over a hundred thousand miles on it and now the engine knocks when we turn it on and I just put new oil in it. What do you think the NACA Muse
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Matthew Hyatt  This “I ran the car out of oil almost completely and it overheated” could be indicative of some major engine damage. From main bearings, to piston/rod damage and camshaft/ lifter/valve damage. I suggest that you have a mechanic at least do an inspection since it is a bit too much to go over. There are just to many variables with this.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Thank you. For the record it was actually my girlfriend after I told her to put oil in it and ran it out of oil and overheated when I showed up it was knocking and had her to shut it off this is exactly what I told her that your answer confirmed it thank you very much
из
Добавьте свой ответ
Matthew Hyatt буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 19
За последние 30 дней: 37
За всё время: 1,709
