6th generation of Motorola's Moto G line. This phone was released in 2018 and features a glass back that is easier to remove than Samsung phones. Model numbers are XT1925-4, XT1925-5, XT1925-6, XT1925-12 and XT1925DL.
35вопросов Показать все
The back of my phone is cracked what can you do
The back of my phone is cracked bad. Can you repair it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Usually yes,but it’s very difficult to do,especially if you haven’t done it before. Since it’s the back,I’d strongly recommend leaving it alone,unless you want to pay a ton of money on a phone that costs less than many out there. I believe they use loca glue(clear glue that solidifies with usb light),as they use it on some lcd screens to hold the digitizer or cover glass on. The back would be hard to replace,and in doing so,you may make it worse,and give up. Any repair place would probably charge more than it’s worth. It shouldn’t be noticeable in a case however.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Emily Zaper будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 420
