The iRobot Roomba 880 is an autonomous vacuum released in 2013, with greater power and cleaning capabilities compared to the previous models.
9вопросов Показать все
4 year old Roomba 880 squealing while running
UPDATE:
thank you for all your responses we determine that it was the side brush motor. Ordered a new side brush motor and No More Squealing! YAY
Again, thank you all for your help
My 4 year old 880 has starting squealing/screaming while running. I’ve cleaned everything but still scrams. I’m afraid it’s the motor, any suggestions
Это хороший вопрос?
Оценка 1
1 Комментарий
Thank you! That’s what we were thinking too.
из
Добавить комментарий
2 Ответов
Выбранное решение
It’s probably the motor, if you’re an expert, you should take it apart - but for most of the time you should ask the previous owner, or company if they can fix it.
Again, what I always say “look it up!”.
Looking it up might not work…
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thanks for seeing this! :)
из
I had a squealing noise in my Roomba too. which I could trace down to the gearing of the extractor brushes.
The motor was slightly displaced so that the gears didn’t connect properly. I was able to fix this temporarily by adjusting the motor with a piece of plastic. but the gears were worn down already so that I had to replace the extractor housing (including motor and gearing). was not a lot of trouble and is totally doable!
I found the housing in the Roomba shop, but it was a hidden link I only found using google… I am not shure what the situation is where you come from but here in Germany this was also the cheapest offer!
Оценка 0
1 Комментарий:
https://shop.irobot.de/de/cleaning-head-...
thats the part I bought for ~45€ while Amazon and Ebay were >60
из
Добавьте свой ответ
SueWormington будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 15
За всё время: 2,664
