Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
The other line doesn't hear me when I use aux headphones
This happens with all the phones I've owned, including the two I still have.
When I make/ receive a call with aux headphones, I can hear the call, but the other line doesn't. Note his doens't happen with lighting or wireless headphones. And it also happens to my LG's.
Это хороший вопрос?
Оценка 0
2 Комментариев
try another headphone
из
I forgot to mention this happens with just about almost every single aux headphone I owned.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
As shown in the image the pin responsible for the microphone is “AUX” , you can see that the GND and AUX pins in the female and male jack are permuted because the microphone will generate the audio (your voice) current, so first try to clean up the inside and put the male jack slightly off it’s max depth, I’ll suggest that you use voice memos or any other voice recorder application.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Now that I think about it, the issue happens with the built in call app, but not with Whattsapp. I still need to scream into the phone so they can hear me.
из
@Wolfgang 847 Maybe the iPhone is detecting the microphone but he don't use it, try to call someone with your headphone and speak through the iPhone microphone, also make sure that your phone is not connected to bluetooth speakers or any other similar devices.
из
Hello
if the microphone is working with one app and not with another it could be a software issue.
I suggest that you make a back up of your phone and restore it.
one other option could be to restore the network settings only. I went for an iphone x with trouble with speaker during call and to my surprise the genious guy resets the network settings and the speakers work again…it is a easy and safe thing to try, you will loose your wifi password but nothing else.
Оценка 0
1 Комментарий:
It is weird because every single phone I have owned has that issue.
из
Добавьте свой ответ
Wolfgang 847 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 138
