The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428вопросов Показать все
Xbox beeps but doesn’t turn on
The night before this happened I was playing a game but the game crashed like 4 different times so on the fourth one I just power my Xbox off. This morning when I tried to turn my Xbox on, it made the powering up noise and the light come on on the Xbox logo button on the Xbox but nothing showed up on the screen and after exactly a minute it turns itself off. I’ve done all the troubleshooting, tried keeping it unplugged for awhile blown in the ports, tried different hdmi cables and TVs but nothing is working. Please help!
Это хороший вопрос?
Оценка 0
3 Комментариев:
Hi Dylan,
And when you go to safe mode ? (Hold the bind, eject buttons and press the power on button). When you heard the 2 beeps, you can release the bind and eject button.
из
It doesn’t go into safe mode I tried and held them down for like a minute and never hear the 2 beeps
из
Hmm.. could be multiple things which are causing this. It’s not overheating as you should see something. I think that your PSU is fine as well. Exactly 1 minute before it turns off, usually means something else (most of the times, not always).
Perhaps the hard drive, that would explain the crashes, but it could be something else. Could also be something on the motherboard (GPU, HDMI Controller, NB, CPU).
Are you able to run tests ? Or test with other parts ?
из
Добавить комментарий
1 ответ
Tronicsfix in his channel has had many unfixable consoles having same symptoms. Hope it's just a bad
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Dylan clay будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 89
