Knob to raise the mixer from the bowl broken,what is the solution
If the knob use in lifting the mixing string, used in mixing, the knob which raise it from the bowl, if it breaks what is the solution
Это хороший вопрос?
Оценка 0
1 Комментарий:
@funmi add some pictures of the broken part etc. with your question. that way we can see what you see Adding images to an existing question
What exact model is your mixer?
из
Добавить комментарий
