The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116вопросов Показать все
1985 mercedes 300d turn signal stop
My turn signals in the dash stop working when the headlamp switch is turned on. I have replaced all the tail lamp bulbs with the correct bulbs and cleaned the contacts it did not fix it i cleaned all the grounds that i could find i repaired broken ground wires near the battery. Need some direction.
Это хороший вопрос?
Оценка 2
1 Комментарий
The left front directional bulb was the incorrect bulb. I replaced both bulbs with the correct bulbs and it fixed it.
Thank you you guys are great.
из
Добавить комментарий
Добавьте свой ответ
kennethsmithea будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 328
