Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596вопросов Показать все
Can I put a Retina display on my older MacBook Pro?
Hi @nuka_kola and @danj thank you for letting us know it's possible! I also have a matt screen 2011 model 15" MBP that died due to gpu failure.
Do you think I could swap in a mid-2012 retina logic board? Or you'd rather go with a non-retina ones? It's the best deal I could find right now but I'm not sure if these two are different in terms of logic board. Will it cause problems when swapping? Thank you!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
A retina system uses a different video signaling method than the older non-retina systems
● Unibody 2012 and older - LVDS
● Newer Retina systems - iDP (also known as eDP)
You need to stick with the display the logic board supports.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Got it. Thank you for the details! I'll continue my logic board hunt.
из
Добавьте свой ответ
Shuju будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 218
