Hi @drasine
You can consider downloading tools like Hiren
https://www.hirensbootcd.org/download/
Once you had downloaded, you can have the option to burn it into a cd or to usb thumbdrive (preferred as it is fast).
You will need another working computer to do so.
There is a tool in hiren you can use to format it.
Hard Disk Tools – Security
HDD Low Level Format Tool v4.40
For a less secure method, you can download windows 10 installer from microsoft, once download is completed, you can either burn it to a disk or usb, which usb is preferred as it is faster. boot it up and delete all partition. After which, you do a clean windows installation over.
For a secure erase, i know there is a tool which can help, but it is not cost effective for you, like wibetech hdd eraser, without a need of pc.
else if it is a concern, and there is no much option left, i would rather you remove the hdd
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
2 Комментариев
Hi @drasine ,
Do you mean a Dell Precision m4600 laptop or a Dell Dimension 4600 desktop computer?
I cannot find any information about a Dell Inspiron 4600.
из jayeff
If it is just removing the physical HDD and is dell dimension 4600, below the cpu casing, there are screws holding on it.
из Augustine
