4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
1049вопросов Показать все
Phone keeps resetting after battery replacement
I recently changed my phones display and when i tried to turn it on phone kept restarting and showing 1 to 4% battery, after restarting even while it is on the charger there isnt that charging symbol next to the battery percentage in the corner. I replaced the battery but it still shows “Service” in the battery health and keeps restarting the same way like it used to on the original battery.
Update (08/07/2019)
Do you guys think this is what causes the problems with charging/rebooting?
Это хороший вопрос?
Оценка 0
2 Комментариев
As you can see that's exactly the component I had marked in my answer, hence yes, that's what's causing the problems.
из
Thanks, I will take my phone to the repair shop and see what they could do
из
Добавить комментарий
2 Ответов
Выбранное решение
Have a look at the small space between battery connector and the metal shield, there are a few small components that may get dislodged when prying off battery. This might be your issue, you’ll need a good light source and better some magnification too..if you see empty solder pins that is it. I enclose a picture for reference.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
The thing is, i waited for a replacement screen for about a month or so, and in that period my phone was sitting without being charged at all, so I assumed that battery just wore out or died because i didnt charge it, but installing a brand new battery didnt help so thats what is bugging me.
из
By seeing the history that is related to the SWI problem ,not connect battery properly or track is broken.
Observe carefully that you got the solution .
Оценка 1
1 Комментарий:
You mind explaining that SWI thingy, im quite new to this.
из
Добавьте свой ответ
Kaid Trako будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 202
