A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
102вопросов Показать все
When should I open my computer and dust it out?
A few months ago, I bought my 5K iMac with powerful specifications, including the 8 core 9th-gen i9 (I now realize that the CPU is socketed and I should have saved money by doing my own operation) and Vega 48 with 8GB VRAM. I use this computer quite often for all of my school work, some video content, and gaming on Windows Bootcamp.
I am aware that dust buildup in the machine can cause thermal throttling over time and can damage the device. Since I have spent so much on this computer, I look forward to buying adhesive strips, opening the computer, and then dusting it off and closing it up (possibly doing some upgrades on the inside using the vacant PCIe slots or putting in a new CPU in 5 years). With all these things considered (how often I use it and all of the technology in there that tends to get hot), when is the best time I should schedule to open the computer and do the dust off? Obviously it’s inconvenient to get inside and requires single-use parts like adhesive, and so I can’t just “check on the dustiness” every so often.
I am wondering if anybody has an estimate of when my computer will start to collect enough dust that it needs to be cleaned out before it damages the computer, perhaps in "x months after you bought the machine” or after the machine starts behaving in a certain way. Is there a routine test I should be running to determine this instead, especially if dust collection is extremely variable from system to system and no estimate is reliable? Thank you!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
First you should take the time to review the Разбираем 27-дюймовый iMac с дисплеем Retina 5K while is an older model its basically the same as yours.
There is very little one can do internally from an upgrade perspective, so don’t over think what you can do here.
As for dust build up I would say every two or so years is about when you’ll need to worry about it. So relax you’ve got plenty of time! The important things are making sure the room you are using it is as dust free as you can make it and use a good surge suppressor or better yet get a UPS. In addition, if you live in a humid area get a dehumidifier and if you live in a very dry area or cold in the winter getting a humidifier. Controlling moisture that can condense on your gear or the risk of static damage when its too dry are the things you can do to prolong your systems life.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Andrew Howe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 85
