Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
25вопросов Показать все
Can I fix my broken charging port?
My charger port inside my tablet either doesn't charge my battery or the screen doesn't want to turn on. When I plug it into my power bank, it does not withdraw power.
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 ответ
if you have a soldering iron and the port is just loose, just solder it back together, however if it is damaged you will have to buy the port off of ebay or someplace like that f you think if you have the skills to repair it. however if you dont, i advise you bring it in to a repair shop
Был ли этот ответ полезен?
по рейтингу 0
Добавьте свой ответ
FaserGamer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 18
