Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
949вопросов Показать все
Face-Id and cameras not working after screen replacement
I have a problem after swapping screens. Swapped Sensor bar on display also. The display is an original from another X.
But Face ID could not be activated on this iphone. Proximity and Ambient sensors work fine. But no face ID. Also both cameras not working properly. When I open camera app…there is a black screen and app freezes. Sometimes the cameras begin to work for 5min. Replaced rear camera but remains the same.
Anyone a solution? thx
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Best guess is that you have damaged or not aligned the connection properly . Try to open the connector and check under microscope or good magnifier both sides . if it looks good reconnect
REMEMBER
Push connector from each end not the middle as this can damage the connector
Был ли этот ответ полезен?
Оценка 0
Комментарии:
Thanks, will check it. But why does neither the rear camera work. Also I got "no audio device found" on Voice Record app.
Sensors of screen are all working...ok I don't know if the flood illuminator works...is there a way to test ?
из
Let me have a look at the schematics Ill get back to you by tomorrow It might all route through a different connector
из
this would be nice ;)
из
Try out the below solutions:
Solution #1: Reset Face ID
It will wipe out all the existing mathematical representations of your face, and you will have to set it up all over again.
Solution #2: Reset All Settings
I know you don’t want to see this unwanted solution, when some problems seem to become a headache, don’t hesitate to give it a go.
Solution #3: Update Your iPhone to the Latest iOS Version
Now is the time to go for the software update. Needless to mention that it’s become the biggest troubleshooter in recent times.
 If Nothing Works contact apple support to help you out and get rid of this problem…
Оценка 0
Комментарии:
Reset everything was the first thing done...but thx ;) !
из
This would work if cameras were working still . Unplug cameras and check connections
из
same problem but when I replaced back screen
Оценка 0
Jc v1s programmer. for iPhone. worth £120 I paid for it. I done 11 pro and it worked and no messages pop up saying this is not original screen
Оценка 0
Добавьте свой ответ
BenjaminS будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 19
За всё время: 1,148
