Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
Why won't my Pokemon fire red save?
Hello,
From the little looking around that I've done myself I've found out that these games don't rely on a battery to store the save files, so that can't be the problem. I've bought the game secondhand with my Gameboy advance about 5-7ish years ago, the game is in German (not my native language) so at the time I was younger and never really got out of the second town. Later I finished the game on an emulator(in English) so I can't recall if it had the problem when I first got it since I didn't speak the language and never knew what button needed pressing to save the game.
I'm able to save the game and it sais it actually saves it, but the number I presume is the amount of times uve saved remains standing on 0. After I restart my GBA I'm forced to go through the tutorial, I've tried it 3/4 times but no success.
Thx in advance for the work,
R.
TLDR; FireRed will let me save but when restarted I'm forced to start all over again.
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
These do in fact have batteries, a CR2025.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
Are u sure, almost everywhere I look it's says specifically that the fire red and leaf green, don't have the CR batteries but flash memory?
из
No, you're correct. What has likely happened is one of the solder joints on the leg of the NAND chip has probably broken off due to age, its possible to be fixed but you will need some soldering equipment and expertise
из
Thx, prob going to let someone have a look at it and fix it.
из
It seems like the save data for the game isn't being properly saved. There could be a few reasons for this. First, the save data could be corrupted. This can happen if there was a power interruption or if the battery failed. Second, there could be compatibility issues with the emulator you're using. And finally, there could be a problem with the hardware of your Gameboy Advance, such as a failing save battery.
To try and resolve the issue visit (https://collectorpricing.org), also try these steps you can take:
  1. Try a different emulator. If the problem persists, it could be the emulator causing the issue, so try playing the game on a different one.
  2. Check the save battery. If the game has a battery-backed save feature, make sure the battery is still functioning. If it's dead, replacing it should solve the problem.
  3. Re-download the game ROM. Sometimes a corrupted ROM file can cause save data issues, so try downloading the game again.
Счет 0
It appears that one of the solder joints on the leg of the NAND chip has broken off. While it's possible to be fixed, you would need to resolder the broken joints by hand.
Счет 0
Добавьте свой ответ
Rik Zwambag буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 17
За последние 30 дней: 74
За всё время: 7,753
