Gray display, everything work fine with external monitor
Hi everyone, i've got a problem with my macbook pro: the computer itself works fine but the display show only a gray screen (backlight work fine too), and i'm forced to' use an external monitor.
Do i need to repair the whole LCD or just the cable?
Это хороший вопрос?
3 Комментариев
Was there a history to this failure? Does the screen do anything when moved up and down?
из mayer
well, some time ago I've had problem just with the upper part of the screen, it began to shade colours to white, while the lower part remain "normal". then if i pressed on the side of the screen for a couple of time it returned ok.
One day i just switch on the computer and the screen was all gray, and did not show anything also if i tried to press the borders... That'it.
Any idea?
Thanks a lot for your answere!
из Matteo
hi guys!
So, today i've replaced the cable arrived from Ifixit... nothing happened!!!
I argue that i'm forced to replace the whole display.... it isn't?
Does anyone have got other solutions? Other cables that i may replace before I'll buy another display?
из Matteo
