The sixth generation Maxima, code-named A34, was only sold in the United States, Canada and Mexico. It was introduced in production form as a 2004 model at the 2003 North American International Auto Show.
25вопросов Показать все
Why won't my car start?
I have replaced both CMS on bank one and two also I had noticed that both of the electrical connectors were damaged so I had replaced those also. While replacing the connectors I had accedently crossed the wires while hooking it back up my mistake, anyway I think I have it all connected back the way it was originally, but now the car won't even start, it turns over but it won't start. Tried many things but, nothing it just won't start, please help
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If you’re sure you left nothing disconnected, try disconnecting the battery for a while to reset the ECU and then try starting it again. If that doesn’t work, try hooking up an OBDII code reader to see what error codes may be stored.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Frank Carignan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 132
