Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA / 64 or 256 GB / gold, silver, and space gray.
408вопросов Показать все
Squares on front facing camera don't line up with plastic on screen
I have just got a front camera replacement for my iPhone 8 Plus and the two squares on the front camera that need to go in the plastic part of the screen do not stay in. They just pop out straight away! Any ideas?
I am referring to parts 7:40 to 8:02 of this video;
https://www.youtube.com/watch?v=2sD9dv-y...
Thanks, help would be hugely appreciated :)
Это хороший вопрос?
Оценка 0
Добавить комментарий
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
Shop Kits
Enough RAM
For All The Tabs
Shop Kits
1 ответ
They often time have problems fitting. You can try to gently peel out the plastic pieces and put them over the square sensors first. The only issue I’ve seen with that is taking those out might cause a scratch on the color paint and it will be visible from the front of the screen. If you try that, use a plastic/nylon spudger to pry those pieces off. Sometimes it just takes some jiggling those square pieces around until you get them in. You may have to push firmly to get them in.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Rafay Siddiqui будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 20
