The V2000 is a Compaq Presario notebook computer developed by HP under the Compaq name. The V2000 is the sibling of the HP DV1000, so the two share many features and specifications, though the DV1000 cost about USD $100 more when both computers were sold in the early 2000s.
The laptop only gets on for two minutes?
after switching on the laptop it gets power off after 2 minutes. and have to wait for 30 min to switch it on again.
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (1)
Выбранное решение
This could be overheating, does the laptop get excessively hot? If so, open it up, and try and clean as much dirt/dust out of it as you can. Dust builds up inside of computers over time, and can clog vents, fans, and heatsinks inside of the computer, causing it to heat up. Clean out the fans and heatsinks, then try it out. If it is still acting up, the battery may be to blame. You can get a replacement battery on eBay for around $25.
Был ли этот ответ полезен?
Оценка 6
2 Комментариев:
+ totally agree. Just in case you need the service manual, it is available at http://h10032.www1.hp.com/ctg/Manual/c00... Good Luck
из
+ also consider replacing the thermal paste
из
Добавьте свой ответ
nlovers2000 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 1,884
