94 Chevy 1500 lights
Drivers side has brake light and signal,
passenger side neither.
All bulbs however are lit with headlight switch on. Just no signal or brake light on passenger side.
i replaced blown fuse and passenger bulb with no change.
Это хороший вопрос?
Оценка
This question was migrated from https://meta.ifixit.com/Answers.
из iRobot
Check the fuse you replaced and see if it blew again. You need to find what caused the fuse to blow in the first place. Do you have a multimeter? Exactly which fuse did you replace?
из Travis
