Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1164вопросов Показать все
No camera functions working
So my colleague replaced the back cover and screen for an iPhone X. By replacing the back cover i mean that we bought a new frame with the back cover already in place. After the replacement the main camera no longer works and the front camera only works sometimes.
I have tried the following:
- Replaced the main camera.
- Replaced the front camera.
- Replaced the flash and on/off button cable.
- Replaced the bluetooth antenna cable.
- Checked all the connectors on the main board and all look fine.
- Did a full reset of the phone 2 times.
All this and nothing worked. I tried turning on the flashlight as well but nothing happened. Any idea what it could be and what to try next?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I’ve seen this a couple times on an iPhone X, and it seems to be a board defect. When you say you tested the board connectors, did you test voltage on the pins specifically?
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you for your answer.
So if it's a board defect it means my colleague didn't cause it and it was a coincidence? I mean it's not exactly easy to damage the board by removing it from the case. The iPhone X board don't really have a lot of exposed components.
Never said i testet the board, i just visually checked the connectors. Maybe i should have been more clear about what i meant. Whats the best way to test the voltage? Is there a tool i can use or a multimeter will do?
из
Try to put it back in the original back case and when it works you know it is a fault in back case that you bought.
Оценка 0
1 Комментарий:
Already have. Same result unfortunately.
из
Добавьте свой ответ
Total Repairs AS будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 53
