A point-and-shoot camera by Kodak released in 2006.
7вопросов Показать все
When I turn on my camera it shuts automatically.
When I turn on my kodak easy share z650 it shuts down.
Это хороший вопрос?
Оценка 1
1 Комментарий
It turns on then it turns back off help
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Camera specifications for the batteries required by this unit are:
Kodak NiMH battery pack KAA2HR, or 2x AA
If battery pack is installed try using a couple of regular AA size batteries to make sure it is not just a charging problem. If camera works with regular batteries, then battery pack and/or charger could need replacing.
If camera still not working after testing, a visual inspection of the camera's interior components may be of use. A teardown tutorial can be accessed at this location:
Kodak Easyshare z650 Teardown
Был ли этот ответ полезен?
Оценка 1
Terri Jones if the check by @propman doesn’t help you want to check the lens. It is not uncommon for these cameras to shut down because of a lens error. Check on here for some possible solutions.
Оценка 1
Добавьте свой ответ
Terri Jones будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 21
За последние 30 дней: 107
За всё время: 2,483
