Отремонтируйте ваше устройство
Обучение ремонту
Магазин
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
82вопросов Показать все
Where is the a.c. condenser drain
Passenger side floor board is soaked
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
There should be a short rubber or plastic tube that hangs out under the passenger side of the vehicle, yours is either clogged with trash or got pulled into the cabin. Remove the glovebox and the blower motor if necessary to access tube and the evaporator case.
Here’s a video that shows you where exactly to look: https://www.youtube.com/watch?v=yKK0P0ks...
Hope this helps, good luck with your repairs!
Был ли этот ответ полезен?
Оценка 3
Комментарии:
@travisjfox you think there is a possibility that this could come from a leaking heater core?
из
@oldturkey03 Definitely. Actually, at first that's what I thought they meant in their question and that by 'drain' they meant the draincock on the radiator. But I believe they meant the Evaporator rather than the Condensor. There is a small tube that directs condensation runoff out of the evaporator case that can actually dump the water into the passenger floorboard. If the liquid is coolant, then it's most likely the heater core, but if it is simply water that is a common complaint on Chryslers of that style.
из
@travisjfox sounds absolutely reasonable. I did the taste test (finger dipped on the floor and not copious amounts :-)as well as the distinct smell on my Jeep GC and I knew it was antifreeze from the heater core.
из
Добавьте свой ответ
novatay1 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 17
За последние 30 дней: 91
За всё время: 875
