I have no picture (black screen). Sound and Ambilight still works.
My Philips 55PUS7101/12 is exactly 3 years old and the screen just stopped working.
I still get sound and light from the Ambilight.
Can I order any part and solve this by myself?
Update with pics from Multimeter 10/9/2019
Goes from 65.5 to almost 0
Power is on
Update 14/9/2019 (CN9101)
Update 3/10/2019
3 images of Main Board
1 image of the power to LED/Ambiligt
Thanks!
Это хороший вопрос?
19 Комментариев
Hey,
did you solve your issue?
из Anton Heuchert
HI, I have the same problem: black screen but backlight is OK
Marcus, you found something ?
THANK’S
из justin288
hello guys, i had the same problem, tv was working but i had a black screen (not even the philips logo shown at startup). my problem was one of the flat cables, somehow it wasn't in the right position.
The two cables were missing small parts from the sides so it didn't fit perfectly. This means that the cable didn;t slide perfectly into position and the very small pins i think weren't toching the right pins from the cable.
After like 5 tries of adjusting the cable, started at the maximum height, and slowly moving the position of the cable lower, i found the right position and my problem was fixed. Of course you have to disconnect and adjust the cable with the TV off and.
I hope this information help you figure it out if it is the same problems.
из emciuc_alex
Hi, my name is Laurent. I am facing the same issue as discribed (no display at all) but audio and ambilight working. Did someone found the solution for this problem ? I already changed the SSB board, but still no VIDEO at all. Thanks in advance for your help.
из Laurent
Hi Laurent! Did you try to shine a strong flashligt on your screen while the tv is on? I have sound and ambilight, but no picture, but when i used a flashlight and looked at the panel i saw picture. As far as i know the background light is controlled by the TCON card.. i found a fuse on my card that didnt look good.
из Peter Lidström
Показать 14 больше комментариев
