A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
131вопросов Показать все
Do we still need thermal control thing for iMac 27 2019?
I read from some threads mentioning about the thermal control thing on old iMacs. Especially when replacing the hhd, we have to buy a thermal control sensor from OWC.
im not sure if we still it for the iMac 2019. Because I’m planning to upgrade the ssd on my own.
can someone help? Thx a lot
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I doubt any of us have done an upgrade on a 2019. Why not get it from iFixit, try it, let us know your results. If you don’t need it, return it.
UPDATE 9/5/19
OWC is still showing the thermal sensors on the models with standard hard drives:
https://eshop.macsales.com/upgrades/imac...
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thx Mayer.
I successfully replaced my HDD to SATA SDD without any thermo-controlling thing. and it runs flawlessly.
I will upgrade the M.2 ssd too after I received the M2 ssd.
из
Dear Taiyuento
I planned to do the same and came across the info on the thermal sensor cable.
Are there any crazy fan noise, I mean high spinning noise, after your upgrade ?
Daniel from Hong Kong
Оценка 0
Hi there, +1 can you please confirm that it is workis fine in terms of fan speed for you?
Оценка 0
Добавьте свой ответ
taiyuento будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 499
