PS4 not powering on model CUH-2006a
My PS4 is not turning on it just beeps once and shuts off immediately. Tried almost all troubleshooting methods on the sony website.
Это хороший вопрос?
Это хороший вопрос?
Method 1: Reconnect the power cable
Reconnecting the power cable can power reset your PS4 and clear the corruption issues on your console. This is the first thing you should try when your PS4 can’t turn on.
1) Unplug the power cable from your PS4.
2) Wait for at least 30 seconds.
3) Plug the power cable back to your console.
Then press the power button on your console and see if this works.
Dust issues can sometimes seriously interfere with your PS4. They can stop your game console from working properly. Cleaning the dust inside is a very effective method to resolve your problem. There are a few things you can try to dust your PS4. For example, you can try blowing into the vents or disk drive or doing some cleaning inside by opening the top plate of your PS4. After clearing the dust, you can start your console and see if this has helped you.
Another useful method is to unplug the power cable and then, seriously, hit your PS4. BE CAREFUL! Don’t hit that hard to break anything, but enough to give it a shock. After that, plug the power cable back and power on your PS4. Then check and see whether it this helps.
Sometimes you can turn on your PS4 by putting in a disk. Your console can detect a disk inserted in and start itself. To turn on your PS4 in this way:
1) Plug the power cable into your PS4.
2) Insert a disk into the disk drive on your PS4. Note that you don’t need to insert all your disk in. Keep pushing it in slowly until you see your console automatically turns on.
3) Pull your disk out.
If this works for you, your PS4 will get back to normal. If it doesn’t, then please try the methods below.
There is a feature built in your PS4 that allows you to rebuild your PS4 database. This will help you clean up the data on your PS4 and sort out everything on the hard drive. To rebuild your PS4 database:
1) Connect your PS4 controller to the console with a USB cable.
2) Press and hold the power button on your PS4 console until you hear the second beep. Then release the button. Your PS4 will be in safe mode and the screen will be look like this:
3) Select “5. Rebuild Database” with your controller.
4) Wait for the process to complete. Then check to see if rebuilding database is helpful for fixing your PS4.
If you have tried all the methods above and you still can’t turn on your console, there may be some issues with the components inside your video game console. And you may need help from a specialist. If your PS4 are still under warranty, you can take it to the vendor of your device or contact Sony support to have it repaired or replaced. Or you can pay someone to fix the problem for you (you need to be careful about the reliability of these service providers).
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 266
