The Dodge Journey is a mid-size crossover SUV manufactured and marketed by FCA's Dodge brand since model year 2009, with a mild facelift for 2011 model-year.
27вопросов Показать все
2009 Dodge journey revs high rmps while driving.
When I drive 30 rpms at 3000 40 4000 50 5000 60 6000 rpmsut has a review while driving transmission not slipping I can still catch speed just rpms and reving as get faster. I have been told many things and noone sas same thing. Any ideas
Это хороший вопрос?
Оценка 1
1 Комментарий:
My car did the same thing. I would have to pull over, shut the car off for a bit, start the car back up and then go through the gears just to make it stop. But in the end. It comes to find out that the transmission solenoid was going out. Now it has gotten to the point that I can't drive the car at all. So now I'm in the process of finding out how to replace it myself.
из
Добавить комментарий
1 ответ
You are probably in limp mode, is what the vehicle does signal you there is an issue that needs correction. Stop by auto parts store to get a free diagnostic code reading or take it into a shop. Sometimes I've heard that disconnect in the battery will reset the computer, Evenstill if it's a major issue it will just reoccur. So honestly the best method is to get it fixed please make sure you go to a mechanic you can trust I've ended up spending over $5000 just trying to identify what's putting my car in that mode
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
emilyisadork7 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 582
