Does the component "Galaxy S7 Speaker" includes the 2nd mic?
Does the component Galaxy S7 Speaker (Global) includes the 2nd microphone (speaker microphone) ?
If not, which component do I need to buy that contains the 2nd mic?
Это хороший вопрос?
Это хороший вопрос?
So the top microphone is soldered to the motherboard?
Anyone knows if the parts are interchangeable. Can I buy just any S7 mic and solder it to the top or to the bottom that it works?
Был ли этот ответ полезен?
Its is not soldered to the motherboard (Logic Board) is is part of the charging dock connector when you buy one no need of soldering
Yes the top one is soldered to the motherboard) Which one is faulty Why do you want to change either one?? I not know about replacing the top mic on the motherboard Never seen one go faulty
The top one is faulty. Nobody can hear me if I turn on speakerphone mode or if I am doing whatsapp videocalls. It also fails the test *#0283# test :(
the mic at the bottom is for phone calls
I be changing the Dock connector first with the bottom mic go from there
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 57
из ARPcPRo
из edigitcom
