Why is my fan making loud noises?
Lately, my mac book’s fan is spinning a lot faster even though there are no heavy processes running on the background. And when I open FaceTime, I get a message saying that ‘Video will resume when Mac cools down’.
I tried resetting the SMC and PRAM, didn’t help.
The Mac is not hot at all. The temperature in my area is 22 degree C.
Это хороший вопрос?
6 Комментариев
Let's get a better view of your internal thermals. Install this great app TG Pro. Take a snapshot of the main window of the app so we can see all of the sensors and the fan (you may need to resize the window) paste it here so we can see Adding images to an existing question
из Dan
I have uploaded the TG Pro screenshot
из Mohit Shah
Hi Mohit @mohit_20.. did this solution work for you ? I am facing the same problem, would be helpful if you respond !
из Qas Fatma
@qasf - Did you install TG Pro as well as run the onboard diagnostics? Did you get the same error code? If you did then you need to have your logic board fixed or replace it.
из Dan
Yes Dan - my problem seems the same as Mohit's. I spilled water on my laptop a while back and now fan is super loud and OS, softwares have slowed down. I was trying to look for a solution everywhere and couldn't understand. Thankfully, i came across this site and read this related post.
из Qas Fatma
Показать 1 больше комментариев
