First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71вопросов Показать все
Where to find a replacement charging port for 1st gen iPad 3G?
I can only find replacement charging ports for the Wi-Fi only model, which explicitly states it will only work with the Wi-Fi only model. Is it really incompatible with the 3G model? Where can I find a charging port for the 3G model?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@defurni you are looking for the dock connector cable. We need to know what iPad you have A1337 or any other numbers on the back of your iPad? Yes, the cable would be different because of layout and connector differences. Looks like your cable would be a 820-2701-A so check on here
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
donald furnival будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 43
