The Nimbus is a wireless game controller released in 2016. It is designed to be compatible with the iPhone, iPad, iPod Touch, Apple TV, and the Mac.
13вопросов Показать все
A button not working
A button not workimg
Это хороший вопрос?
Оценка 2
1 Комментарий
My steelseries nimbus button “B” not working
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
If you have only just noticed some stickiness or you’ve just spilled something on your controller, you only need a minor cleaning around your buttons. Grab some Q-tips and some rubbing alcohol for this quick cleaning tutorial.
  1. First, unplug the controller.
  2. Dip the Q-tip into the rubbing alcohol, dabbing off any excess.
  3. Rub the Q-tip around the button that is sticking several times, getting as far into the crevices as you can.
  4. Once you think you’ve cleaned out as much as you can, press the button a few dozen times to work the rubbing alcohol into the crevice and loosening any debris left behind.
  5. If the button still sticks, repeat this process or try another method lower on this list.
Rubbing alcohol evaporates quickly and you shouldn’t be using enough to do any damage to the circuitry inside the controller. Never clean a controller with water as it can get inside and cause corrosion and circuitry damage to the controller.
Lewis
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Great.. Its working!!
Thank a lot
из
can you mark it as an answer? Thanks.
из
Добавьте свой ответ
Scott Okada будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 1,508
