Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3966вопросов Показать все
How do I measure output voltages at Tristar?
I am trying to figure out why I can get the voltage readouts from VCC Main and Batt VCC, but not other lines, even when VCC main is the supply for that IC. For example, Chestnut is supplied by VCC Main, but when I try to measure the 6v Boost at C329, I get no voltage?
What is going on here and how do I measure outputs, please give an example such as chestnut or tristar adn how you would go about measuring outputs.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Комментарии:
Have you got your screen connected when checking 6v Boost?
из
Добавить комментарий
1 ответ
Выбранное решение
When measuring voltage rails, they are all done in the same manner. So if you are successfully reading VCC_MAIN and BATT_VCC for example, the same method will apply to reading PP6V0_LCM_BOOST. Now obviously, you have to insure you are probing the correct side of the capacitor (not the ground side).
Some rails don’t give the expected voltage under passive conditions, such as a logic board connected to battery only because the power IC is waiting for some kind of timing signal or feedback loop. A good example of this is the ANODE line, it will only read the same as VCC_MAIN unless it detects a screen, in which case it will boost the voltage.
Unfortunately, without seeing you in action, I can’t really say if you are doing something wrong. It may be that you are probing a dead circuit and that it is “normal” that you aren’t reading anything. Check on constant rails such as PP_CPU to see if you can measure some voltages.
Был ли этот ответ полезен?
по рейтингу 2
Добавьте свой ответ
pts8091 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 27
