The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
The brush rotates intermitantly, seems as if there is a loose wire
The suction is fine but, the roller brush rotates intermittently. It re-engages when I bounce the LiNX but not always when I turn it on and off. There seems to be a loose wire or connection somewhere. Any suggestions will be most welcome.
Это хороший вопрос?
Счет 4
Добавить комментарий
1 ответ
I had a similar problem. However, my wire was severed. I had to open up the head unit and resolder it back together. Since that fix I have not had any issues.
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
Was the problem intermitent? Weems a severed wire would make it not work at all?
из
Yes mine works intermittent too, not sure what is causing this.
из
Same issue. I cleaned the brush but still doing it.
из
Добавьте свой ответ
Alan McDonald буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 14
За последние 30 дней: 58
За всё время: 851
